Idler pulley
Idler pulley
Hello, does someone know how you go about changing the idler pulley on the 07 vibe. Its not the belt tensioner just stationery pully that turns, roughly in between the alternator and air conditioning unit and just to the right of tensioner. It looks like it must be pressed on to the shaft ?
The motor mounts has to be moved on the pass side and jacked up about an inch, To allow belt tensioner Bolt to be removed, It is on the back side. Belt was tricky to put back on, The link is above, If you do it, I would take pics of every thing. Good luck.
Thanks, but the ones i see in the video are for tensioner..but its actually not the tensioner pulley..not the one you pull on to remove belt...it is the pulley to the right of it..same diameter and there is no bolt head..it is just straight flush with end of pulley?
I looked at the GMPontiac Grand P one on the same page, Does it look like the same one as yours? I would also ck the auto parts store for ONE and ask them also, Sorry, I will keep searching. Are you sure there no bolt in the center of it?
#6
Hey thank you for helping out..i had a brain fart going on, it is actually the water pump..i was driving to work and it all of a sudden hit me.. the last water pump i had ever changed was on a 86 350 chevy. Anyways thank you, i appreciate you helping out
