could it be clutch
Old 07-22-2006 | 08:06 AM
sunfire97's Avatar
Default could it be clutch
I have a 97 2.2 sunfire. I recently noticed that at idle and out of gear a light knocking sound coming from the front. You can hear it inside as well as outside although neither is really loud unless you pop the hood. As soon as you push in the clutch over half way it stops. Theres also a slight popping in the clutch everyonce in a while when downshifting and Ive noticed the shifts are getting a lil stiffer sometimes. Im thinking its the throw out bearing I had an izuzu rodeo make the same noise although it didnt go out untill the noise got really noticable but I just wanted to make sure. Thanks in advance.
Old 02-04-2007 | 04:10 PM
klausmann's Avatar
Default RE: could it be clutch
Hi,
Just noticed that your note got a lot of hits but no replies.
I have a 2001 Sunfire that has 251,000 kms (160,000 miles) and the gear shifter is just starting to really stick (OK, it's JAMMED solid sometimes). It used to do that only when it got very cold outside, but it's doing it all the time now. I don't know if I'm gonna get to work on Monday.
Do you still have your '97 and did you get your problem resolved?
klausmann
Old 02-20-2007 | 11:55 PM
klausmann's Avatar
Hello...
(I don't think there's anybody out there...)
Old 03-14-2007 | 11:16 PM
ThePontiacKid's Avatar
maybe its just the trannys getting all old and worn out. i dont see how a clutch could be making that sound..however i could be wrong.
bnork
08-22-2009 11:09 PM
laracroft
07-11-2008 05:08 AM
Kjamac
05-18-2008 10:55 PM
dirt_trac_racer_80jr
11-13-2007 01:01 PM
laracroft
01-22-2007 10:14 PM
Quick Reply: could it be clutch
