3800SC in my '96 Sunfire - Tach Issue
Old 12-16-2007 | 01:44 PM
SunfireSSR's Avatar
Default 3800SC in my '96 Sunfire - Tach Issue
I need to know how to get the Factory Tach in my Sunfire to work with the '99 GTP 3800SC engine I put in it. I've tried feeding the signal from the V6 crank sensor to the PCM with no luck.
I did pull the Instrument Panel Cluster (IPC) out of the Sunfire to replace some bulbs. Inoticed a (4) Pin connector on the back of theGauge Face Plate for the Tach as well as the Speedometer.Don't know if I can hook something up here or not.
Want to keep the sleeper look inside and outside of the car. Everything in the Cluster works except for the Tach.
Any help will be appreciated. Thanks...
hyke
10-04-2008 11:25 PM
buckeyebeaver
04-16-2007 09:18 AM
greg @corkle
07-03-2006 06:30 PM
mpa53167
06-17-2006 09:28 PM
radioren
06-09-2006 01:14 PM
