Montana windshield wiper stuck up
Old 12-07-2006 | 12:00 AM
basmith's Avatar
Default Montana windshield wiper stuck up
1999 Montana. When we turn off the windshield wipers they end up straight up and down on the windshield.
When turned off, they hesitate on the bottom and then before they would normally go below the hood to the off position they now go up and stop.
Old 02-23-2007 | 10:51 PM
Revredneck's Avatar
Default RE: Montana windshield wiper stuck up
There's a funny looking mechanism on the wiper motor that lets the wipers park. I think it's called a parking cam. You should have a look at that thing. There was a recall on them in the late '90s. You might check on that, too.
Old 04-10-2007 | 10:53 PM
salcock's Avatar
i had a simular problem with my wipers and found out that the parking plate which i call it went out of sequance due to the bolt holding down the plate came loose disconnect the main arm on the motor and run the wipers so it could go back to its origanal position and manualy bring the wipers down to the bottom of the window reconect the arm and it should be ok
p.s i had to do this a couple of times before i got it right
Old 06-07-2007 | 01:26 PM
sleder's Avatar
Yes you are right its called a wipper park arm while your looking at it there should be atab sticking up from were the park arm is mountedthat actually catchs the rotating park arm to park it this usally gets bent down this happens in the winter if they were frozen at one time.
jeff618
11-18-2010 10:06 AM
wannagofast
1st Generation 1967-1969
03-30-2009 11:04 PM
Dan Ro
12-07-2008 01:43 PM
glguy82
10-30-2007 11:29 PM
572_IROC
3rd Generation 1982-1992
08-30-2006 09:30 PM
