Car Wont turn over all i get is clicking sound
Hey my names Steve i just purchased a 96 Grand prix SE, one of the bulbs was out in my speeDometer so i went to go change it and in the process of trying to take out the gauge cluster i was unable to disconnect the wireharness from the bottom of it, then when i went to start the car wouldnt turn over, all i get is a clicking sound like the starter wont ignite the engine.... any help would be great to wer ei should start checking ... THANKS!
RE: Car Wont turn over all i get is clicking sound
That "clicking" is your starter solenoid doing it's job. My suggestion to you would be to check the battery.If the battery is okay checkfor a voltage draw. It's entirely possible that when messing with the instrument lights you mayhave opened a draw. This can be checked by turning off EVERYTHING in your car, disconnecting the negative batterycable, and attachingthe "alligator clip" part of a test lightto it. Then probe the negative terminal of the battery. If you get a light, you have a draw. If this is the case be prepared to spend some money. Also, are you getting any "battery/charging system" lights on your inst. cluster. A bad alternator may actually be draining your battery...this is an outside possibility.
Good luck friend,
-Thomas-
Good luck friend,
-Thomas-
hypebeast_d
11-11-2006 06:15 PM
