P0341 Code on Pont. GrandAM 2001 6Cyl 3.2L
Old 05-27-2008 | 03:15 PM
Cougiaurmeh's Avatar
Default P0341 Code on Pont. GrandAM 2001 6Cyl 3.2L
My wife's car, a Pontiac Grand AM SE1 2001 6Cyl 3.2L is having a "check engine" light on every now and then, and it's interfering with our safety inspection. The engine runs fine, however. I researched the code and found out it had to do with an intermittent fault on the camshaft position sensor, and found the problem could be anything from a loose wire, to a camshaft sensor, to an element on the camshaft.
So, I think I'll get it diagnosed at a shop, and then fix it myself. Now, does anyone know any good companies that can diagnose for cheap?
I'll return to this thread when the problem is diagnosed because next I need help knowing how to fix it. I learn fast and have an affinity for mechanical stuff, just cars are a tad new to me among other things.
Old 09-27-2010 | 03:32 AM
boydfoose's Avatar
try this website http://www.obd-codes.com - I had the same problem from the past! Today's car are very digital. too much tech stuff on the dashboard.
pontiac grand am parts
crpowell08
Front Wheel Drive 1987-2005
03-28-2011 07:58 PM
6.0goat
03-04-2009 01:45 AM
glaranotch
09-24-2008 01:54 PM
94grandam
04-28-2008 10:06 PM
trickydick
3rd Generation 1982-1992
6
03-13-2008 02:01 PM
