grand am 1999
Old 05-13-2006 | 12:52 PM
vikicar67's Avatar
Default grand am 1999
My grandam has been running sluggish and the check engine light is on. I have replaced the spark plugs and wires and also the ignition coils. the light is still on and it still has a bad take off. the vehicle seems to burning more fuel. it has been hooked up the machine and they can seem to figure it out.
Old 09-15-2006 | 03:53 PM
Jeremy@fredbeans's Avatar
Default RE: grand am 1999
If the light is then there should be a code stored. Possibly a Converter issue.
Old 01-10-2007 | 08:53 PM
flashy grand am's Avatar
have you reset the computer (key in ON position, push gas petal to the floor 3 times normal force don't slam it) reset it and if the light comes back on than you should be able to check it with the machine
Old 03-04-2007 | 01:57 AM
GrandAMGT4's Avatar
a lot of time itsa computer issue
Old 03-09-2007 | 06:01 AM
grandamkid's Avatar
[align=left]Have the codes pulled so you can diagnose the problem.It also could be your o2 sensor if you are burning more gas it could also be a transmition problem.My car did the same thing.Does you check engine light come on when you reach a certain speed?
[/align]
ShaunReed
01-16-2011 11:39 AM
lady karen
Front Wheel Drive 1987-2005
06-19-2009 05:02 PM
flashy grand am
01-10-2007 06:03 PM
flashy grand am
01-10-2007 06:00 PM
killzoneq2
07-17-2006 08:56 PM
