Which OBD system do I have?
Old 07-04-2006 | 02:37 PM
redandsilver88's Avatar
Default Which OBD system do I have?
I have an 88 Fiero GT and I want to get a code reader for it. Which OBD reader do I need?
Old 10-04-2006 | 10:24 PM
smartasguy_68's Avatar
Default RE: Which OBD system do I have?
well i can tell you its not OBD II..
Old 10-29-2006 | 12:37 AM
Baja4Autism's Avatar
You need an OBD I tester that simply flashes light blips that you must count as they are sent. It will take a few times to get use to it. Most OBD I testers will send the codes twice in sequence. You may want to check a local Autozone store for a GM key which is simply a small metal shaped key that acts as a jumper at your test connector and then utilizes lights on your dash board to send blips, which in turn provide you with the codes. These keys are FREE from your local Autozone. You can also make your own OBD I tester by making a jumper wire with some 16 gauge wire and a few solderless connectors or alligator clips. If you need more info, let me know via e-mail at baja4autism@aol.com.
Brian
cwwidner
09-01-2007 09:13 AM
Wip
03-10-2007 10:13 PM
frankenchicken
01-18-2007 08:43 PM
frankenchicken
01-16-2007 05:24 PM
Tez
09-13-2006 05:05 PM
