losing fuel pressure
Old 06-01-2008 | 06:50 PM
cabits's Avatar
Default losing fuel pressure
Had 169,000 miles on the engine and it was getting hard to start so I checked the fuel pressure and it was about 30 psi. I replaced the filter and installed a Walbro pump in the tank. Turned the key on and it wouldn't hold pressure for more than a second or two but with the engine running it was about 40 psi so I put a new pressure regulator in and the same thing happened. I was wondering if the problem was the Walbro pump not having a one way valve to stop the pressure from returning to the tank. Anyone else run into this problem? Now I just have to turn the key on wait a second for the pump to build pressure and it starts but if you just try and start it like most other people do it takes a few seconds of cranking to start.
jerryh20
05-20-2008 11:38 AM
revitup600
04-26-2008 08:27 PM
omegnus11
Front Wheel Drive 1987-2005
02-09-2008 04:10 PM
MS
01-27-2007 10:10 AM
96RAMAIR
03-30-2006 01:48 PM
