exhaust pops
Old 04-02-2010 | 10:08 PM
gpguillemette's Avatar
Default exhaust pops
I have a 1968 GTO with a 461 stroker that was running strong last fall. Over the winter I pulled the heads, Eldebrock aluminum RPM's, to do some machine work.
I put it all back together and now I am getting a pop out of the exhaust when I back out of the throttle. The idle is a little rougher than it used to be also. I checked the ignition completely which is good. I replaced the power valve also.
The gas in the tank was from last year but had Stabil in it. I also put gas in it with octane booster. The local gas station doesnt have race fuel yet.
I am wondering if the intake gaskets did not seal properly but i've never had a problem with that before.
Is there somewhere else I should be looking or a definitive test I should do to localize this problem?
Frustrating!!!
Old 04-03-2010 | 08:46 AM
nj85z28's Avatar
Administrator
Any way your timing could be out?
dragongirl747
06-15-2007 01:01 AM
greg @corkle
07-03-2006 06:30 PM
AndrewNmandy
05-17-2006 10:53 AM
JRPGTO
05-01-2006 07:15 PM
Speed Engineering
Member Group And Special Buys
10-08-2005 07:55 PM
