Water pump bypass
Old 02-04-2009 | 02:08 AM
oldman41's Avatar
Default Water pump bypass
Hi All, being new here, I've obviously got a question. Trying mount an Edelbrock X2 6X2 crossram on a '62 engine, we've run into a problem. The X2, like the Offy dual quads, is designed for 55-early 64 Pontiacs. Both the X2 and the Offy's lack the receptor that the water pump bypass goes in to. The ports for the water crossover are no problem. There's 2 on each side and one pair gets capped depending on the year. That makes the crossover work with heads from 55-early '64 with no problem. The problem with water pump bypass has us stumped. Can the bypass be capped on the timing cover?
Interestingly, Edelbrock P22 2X4's will fit 55-early 64 using the same water port system. However, they do have the receiver for the bypass. What happens if you run one of them on say a 57? Strikes me you'd have a large puddle on the ground from the bypass receiver that has nothing going to it.
HELP, HELP, HELP. Now that I've got that off my chest, thanks in advance, Art
feniansoul
12-12-2008 02:09 AM
feniansoul
11-26-2008 10:46 AM
austinjw
07-08-2008 12:00 PM
fuzzydog1
02-24-2008 02:24 PM
wbxcitmnt
10-28-2006 03:25 AM
