how do i wire a sat radio to come on with key
hey i own a saturn sc2 , and i do a lot of mods or actually already have. but anyways i have a friend that owns a 06 G6 and i was woundering what fuse i could connect to or even an ignition wire if i knew the colour. for hooking up a satilite rdaio to come on with his keys, i know this can be done..any ideas??thanks
xm
Hey -
I'm not totally sure either, but figured I'd toss this out there
You probably don't want to connect anything to the ignition switch/wiring because you might run the risk of overriding any potential default control module settings programmed to shut down the radio, interior lights, etc. It's been a while since I last looked at the back of the latest GM radio design(s), so the only option I can think of would be some sort of FM Modulator connected to the back of the radio - but you'd have to hack-in and program it to recognize the frequency of your transmitter. Whewww..!
Anyhow - I'm trying to figure out whether I should buy out the rest of my wife's G6 GMAC lease before it ends. It's been a solid vehicle and I know the cost of extending the warranty is probably affordable. Your thoughts?
sponnerjhon
04-06-2012 01:46 PM
