HUD display
Old 08-27-2005 | 11:46 AM
nj85z28's Avatar
Administrator
Default HUD display
sometimes my Head Up Display gets kind of dim even though i dont touch the dimmer. anyone know if it could be the dimmer itself or maybe something else> loose connection? anyone
Old 08-29-2005 | 04:34 PM
Patrick's Avatar
Administrator
Default RE: HUD display
does it flicker, or just stay dim?
Old 08-29-2005 | 07:57 PM
nj85z28's Avatar
Administrator
it stays dim for a little bit then gets bright again. sometimes it stays fine for weeks and then once in a while it gets so dim i cant even see it
Old 08-30-2005 | 04:21 PM
Patrick's Avatar
Administrator
it sounds like a loose wire..or some electrical issue
Old 01-13-2006 | 03:24 PM
joshlarsen's Avatar
I have the same issues with my HUD on my 99. It is dark most of the time now and you can only see it every once in a while even in the dark. I never touch the dimmer switch but it gets dim and bright all on its own. GM has replaced the dimmer switch and that did not resolve the issues. does any one have any other ideas?
  #6
Old 01-14-2006 | 03:14 AM
nj85z28's Avatar
Administrator
no i still couldnt figure mine out.....weird
  #7
Old 06-26-2006 | 12:30 AM
gititdone's Avatar
Strange but true I have been having the same problem with my HUD except now it rarely turn on. Sure is nice when it does work. Any suggestions would surely be appreciated.
  #8
Old 11-07-2006 | 07:37 PM
GrindingNemo's Avatar
I too have the same issue with the HUD. The dash display showing fuel range/oil life also fades in and out/resets too. I'm thinking new alternator? I've already replaced the leaky battery that was installed when i bought the car.
  #9
Old 12-04-2006 | 02:28 AM
nj85z28's Avatar
Administrator
its actually a "cold solder" problem. there is a fix for it, which involves taking the unit out and correcting the solder joints. i helped fix one a few months ago
drummerboy10189
03-13-2013 12:34 PM
davehecky
01-30-2008 11:07 PM
HarryO45
12-05-2007 07:16 AM
TrbGTO57
07-20-2007 05:29 PM
