cheap ignition key
Old 09-06-2006 | 04:01 PM
ventport's Avatar
Default cheap ignition key
I went to the local GM dealer to get an extra key for my 2002 GP and the parts man said they were $63 each. Is there a place on the internet or somewhere else where they can be purchased more reasonably? Thanks Brian
Old 09-15-2006 | 03:58 PM
Jeremy@fredbeans's Avatar
Default RE: cheap ignition key
The part number is 88951932. Hopefully this helps you in your search for cheaper key.
Old 09-15-2006 | 05:27 PM
ventport's Avatar
Thanks for the reply. I was told that the key has a chip in it that is specific to my cars VIN # or is the key programed to my VIN#. In either case I still have to get it from GM and programed to my car at $63 each, am I correct? If not can you or someone clear this up for me? Brian
Old 09-15-2006 | 05:31 PM
the programming procedure is simple....put the original key into the ignition and start the car...turn off the car....and within a few seconds....put in the new key and start the car....that's it. You can get it cheaper if you call this number 484-931-4800 they have discounts on parts and will ship it to you.
namato1
08-29-2011 08:27 PM
bbybls
11-07-2007 04:57 PM
cbjreutzel
11-02-2006 07:05 PM
sunfirebabe22
06-16-2006 06:28 PM
vinnydemarco
3rd Generation 1982-1992
01-15-2006 01:53 AM
