Change Oil Soon Light
I have a 98 3.8L GT and the Change Oil Soon light stays on for about a minute every time I start my car. It started happening around 94k miles. I change the oil every 3k miles so I'm not sure why the light stays on.
Any ideas would be appreciated.
Thanks,
-Nick-
Thanks,
-Nick-
RE: Change Oil Soon Light
u might want to check your oil pan gasket. i have the same problem in my 97 GT and a mechanic said there is a leak in the pan and it causes engine oil pressure to be waaaaaaaay off when u start the car but after a few seconds the engine will build up the necessary amount of pressure and the light will go off. which is what mines does. hope this helps.
Change Oil Soon Light Pontiac
I faound a site where you can find how to reset change oil soon light for all Pontiac models. http://resetservicelight.com/categor...light-pontiac/
The full procedure how to reset oil warning light for Pontiac is taken from owners manual
