Serpentine Belt R&R?
Old 01-10-2008 | 05:10 AM
LC's Avatar
LC
Default Serpentine Belt R&R?
'99 Bonneville SE 3.8L
I bought a new belt & released belt tensioner & took belt off pullys, but it seems motor mount brace is preventing belt removal[]
Please tell me the General didn't design set-up, which requires brace removal, inorder to pull old belt outta there?
Bottom line = What is required to get the new belt on there?
Thanks,
LC
Old 01-17-2008 | 08:53 PM
98silverbullet's Avatar
Default RE: Serpentine Belt R&R?
Not sure if it is exactly the same set up but, I had a 99 grand am gt. The bracket spanned across the front of the motor to a support on the sub frame which prevented me from installing a new belt. The bracket had 2 bolts. I loosend both but removed only one, slid the belt between, re-installed that same bolt then removed the other to get the belt on. I had an air rachet at the time so it did not really slow me down much. After that it's all good!!!
Hope this helps
richardjrose
06-12-2011 10:24 AM
tydwell
Front Wheel Drive 1987-2005
01-22-2008 06:00 PM
hhjr
11-17-2007 04:08 PM
l_inda
11-16-2006 11:05 PM
PaulZo
10-09-2006 06:57 PM
