2000 2.4 no fuel pump activation?
I am working on a 2000 grand am se1 2.4l the car will not start, it will fire on starting fluid, it has a few codes, but none that would keep it from running, when i used a genisys scan tool, it siad the fuel pump relay was no activated? is this a problem with the pump or the relay or the pcm??? please help
The something happened to me, it turned out to be the Ignition/Pass Lock Cylinder, which the dealership had to install and reprogram the computer. I have gone threw 2 in 19 months. The second time the BCM computer also went, which I was told is normal when the Ignition/Pass lock goes, and I got lucky the first time. Its not a cheap fix, it cost me over $1000 the second time and the dealer has to do it due to reprogramming the computer. Unless you know a GM tech that can bring home the computer and do it for you on the side.
