How do you fix a speaker from cutting in and out?
Old 05-27-2007 | 09:20 PM
SpeakerQuestioner's Avatar
Default How do you fix a speaker from cutting in and out?
please answer my question.
also is it the same for all speakers cutting in and out?
please and thank you.
Old 05-31-2007 | 01:58 AM
KansasCruiser's Avatar
Default RE: How do you fix a speaker from cutting in and out?
It usualy breaks down to what is causing the speaker to cut out. It is usualy one of a couple things.
1. Wiring
A. look at the connections on the speaker. if they are on solid then move on to B
B. Either follow the wire from the speaker to the amp using an Voltmeter looking for shorts or just replace the line.
2. you could have a problem in the head unit itself or in an amplifier.
A. I would try rewiring the speaker first
Old 11-25-2007 | 11:43 AM
badbob52's Avatar
I've got a problem with a 92 Transport. Front right speaker (top of the dashboard) appears to have a loose connection problem as it cuts in and out and crackles.
Was wondering what's the easiest way to get to the wiring connection.
TIA for any help.
carlsonj2
06-25-2009 08:47 AM
dave anderson
11-13-2007 01:54 PM
PonchoFan
08-27-2007 12:15 PM
BrianC02
12-29-2006 12:11 AM
kerrick
07-06-2005 03:43 PM
