1965 bonne help
Old 10-10-2007 | 08:18 PM
got2havit101's Avatar
Default 1965 bonne help
Hello everyone.....I have a 1965 2dr bonneville coupe 389 tri-power, the engineturns but will not start. I prime the carbs and she will fire right up and keep running but when i turn off the bonne and try to restart her, she just turns and turns. Once again i have to prime her with a little gas and she fires right up. Does this sound like a fuel pump issue????? Your help would be greatly appreciated
Old 10-25-2007 | 02:24 PM
mrrat1's Avatar
Default RE: 1965 bonne help
Hi have you found your problem yet? You can check the pump by disconnecting the fuel line at the filter and run it to a coffee can. turn the engine over and fuel should flow into the can. I had a similar deal in my GTO. The pump eccentric was broken, it is on the end of the cam & turns the fuel pumpwhen the engine is running. HTH Dave K.
Scootertrash
01-09-2009 10:23 PM
got2havit101
10-10-2007 08:07 PM
got2havit101
10-10-2007 08:02 PM
DRKGRN01SSEi
07-21-2007 03:56 AM
DRKGRN01SSEi
05-14-2007 01:23 PM
