455 WM block
Old 03-29-2007 | 12:31 AM
Dan68's Avatar
Default 455 WM block
My 1968 GTO has a 1972 WM code 455 cu.in block. All my research indicated this should have 4 bolt mains.and came from a 1972 Trans-Am. I am in the processreplacing the rear seal, and when I removed the pan was surprised to see 2 bolt mains any answers to this question would be appreciated. Dan
Old 04-05-2010 | 05:43 PM
8ubterfug3's Avatar
What is the actual casting code? That'll tell you for sure what's supposed to be under there.
http://www.pontiacpower.net/engcode01.html
Old 05-03-2015 | 03:28 AM
cuz68's Avatar
Dan68 Your unit # at the back top of your block near dissy numbers,485428 are Ram air 4 bolt mains, The #s wont lie, See if you can find them 485428. Good luck.
Tim
05-23-2017 09:42 PM
petevalencia
04-25-2015 02:10 AM
81turbota
08-07-2008 06:10 AM
blzmann
2nd Generation 1970-1981
07-16-2007 07:39 PM
GTOman155
10-12-2005 03:24 PM
