400 blocks
Old 04-12-2007 | 10:40 PM
Dustin's Avatar
Default 400 blocks
Is there any difference in the block or short block of an early 400 and a later model like a 1975 400, Is all the H.P. difference in the heads and carb?
Dustin
Old 06-01-2007 | 07:57 PM
KansasCruiser's Avatar
Default RE: 400 blocks
earlier modles had higher compression so more power then the late models. And yeah the heads where different. carbs are about the same though.
Old 02-21-2008 | 10:02 PM
cppainter's Avatar
bores and stroke were all the same, heads intakes were different, watch later 400's 78 and up had weaker oil pumps for some reason with a smaller pickup screen
Old 04-05-2010 | 05:39 PM
8ubterfug3's Avatar
As cppainter said, Pontiac did almost all of the power decreases using larger combustion chambers in the heads, and also don't forget about the SAE power rating change. Just check through this page showing the combustion chamber volumes and see what happens once 1971 and later rolled around.
http://www.angelfire.com/fl4/pontiacdude428/HeadID.html
MotherHD
06-01-2013 03:59 PM
Indyhac
09-07-2011 12:03 PM
81turbota
08-07-2008 06:10 AM
jram
10-31-2006 01:31 PM
markymarco
10-14-2006 04:06 PM
