1964 GTO windshields metal trim.
Old 06-11-2007 | 12:57 AM
bsakennyh's Avatar
Default 1964 GTO windshields metal trim.
Hello,
I am new to this site. Can anyone tell me how to remove the metal trim around the front and rear windows of my 1964 GTO? I must re-seal the windows and do not want to crack them. I do EVERYTHING myself!!
Kenny.... khargens1024@msn.com
Old 04-24-2015 | 01:49 AM
cuz68's Avatar
Wink
Thay make a tool just for that, You can get one at a auto parts or Paint place Thay are around $10. Be slow and eazy with them.
Old 12-18-2017 | 04:53 AM
WarrenWebb's Avatar
The tool that cuz68 refers to is a simple hook shaped tool widely available. Using it one has to be very careful. You should insert the tool under the trim molding & very slowly turn the tool to release the clip towards the glass. It doesn't take much movement either, maybe just 1/8" or so to release the clip. What makes it a bit tricky for a novice is if you twist the tool too much the hook end can chip & ruin a perfectly good windshield. Same goes for the backglass except there if the glass is chipped it will self destruct into a thousand pieces.
steinerj56
Classic 1964-1974
05-03-2015 02:58 AM
mikejordan
Rear Wheel Drive 1962-1987
02-23-2012 05:30 AM
79gppontiac
09-26-2008 03:59 AM
greasywrench
06-14-2007 12:38 PM
thequietone
08-09-2005 05:20 PM
