BonnevilleWhile this model began its run as a full sized model, and shrunk down to a mid sized model in the 80s and 90s, it has returned to full size sedan status to be the flagship luxury model in the Pontiac lineup.
Are the camshaft and crankshaft position sensors located in the block of the engine somewhere. I suspect you would need to remove the oil pan to access. Correct?
Thanks
