Need help with speed sensor
Old 10-03-2007 | 12:39 PM
2000 T/A's Avatar
Default Need help with speed sensor
Got a 2000 T/A and I must have ran over something cause my left front speed sensor wire was pulled down and ripped apart. There is enough wire left to where I can solder them back together. However when I called the Pontiac dealer they said that I could do this cause it would change the resistance of the wiring and would hence still throw a code keeping my ABS and TCS inactive. Instead they want me to by the whole front hub for 400 bucks plus another 200-300 for install. Are they just giving me BS to make money or can I just solder the wires and be fine? Thanks
Old 10-05-2007 | 09:24 PM
Firebird79350's Avatar
Default RE: Need help with speed sensor
They are right about soldering it, anytime you pull the wires apart the resistance will change by a very minute amount but the computer will still notice the change and will throw the code. I would suggest finding a T/A that has been wrecked that would still have a hub on it and just pulling that one and installing it, it would save you about 200-300 bucks. Installing a hub doesn't take much work and if you need help putting it back together you can always look at the one on the other side of the car for a reference.
daisybop23
02-17-2008 01:30 PM
Ashley
09-11-2007 10:44 PM
hhjr
03-20-2007 01:04 AM
Pablo_UA
3rd Generation 1982-1992
03-16-2007 07:37 AM
pretishia38
10-28-2006 03:17 AM
